nollij
- Washington
I have another real treat for some of you folks out there with an opinion or two.
Background:
API RP 500 section 5.5.5 states:
"In mixtures of manufactured gases, the mixture should be considered Group B if the gases contain more than 30 percent hydrogen by volume."
NFPA 497 section 3.3.5, the definition of Comustible Material has the definition for the Groups of materials based on their Maximum Experimental Safe Gap (MESG; section 3.3.9) and Minimum Igniting Current (MIC; section 3.3.10). The breakup for the various Groups are as follows:
Group A: Acetylene
Group B: MESG < 0.45mm or MIC <0.40
Group C: 0.45mm < MESG < 0.75mm or 0.40 < MIC < 0.80
Group D: MESG > 0.75mm or MIC > 0.80
Now, on to the dilemna. Currently, there is a fuel gas line that runs the length of the refinery that was never considered part of the original plant classifications. This fuel gas line would be Group B per the API RP 500 definition. However, per NFPA 497 calculations, the mixture would fall into the Group C category. There is enough of an impact that going "eh conservatively, its Group B" is not an acceptable answer.
So far, we have gotten jumbled responses ranging from "NFPA 497 is actually law to API RP 500 is the common accepted industry standard."
My opinion: NFPA 497 is more in line with how the equipment is constructed for the hazardous location groups. It is also a more technical approach for what would actually cause an ignition. Therefore, it may be prudent to adopt the NFPA 497 method for defining material groups. However, if this is the method used for this process stream, the rest of the refinery should maintain that consistency (ie, you don't use NFPA 70E Arc Flash calculations when convenient and then use IEEE 1584 in other places).
Thoughts? Criticisms? Opinions?
Thanks.
Background:
Group A: Acetylene
Thanks.
