A lot of the ?ifs? and such depend on whether all the motors were running when you took your readings, what size wire was used to feed power to this Motor Control Center from upstream, and what the rating is for the upstream overcurrent protection device. But I would agree that the number of amps available should be no higher than Tom?s stated 117. By the way, that number is based on trying to keep the load below 80%, or below 160 amps.
