A anbm Senior Member Location TX Occupation Designer Oct 17, 2012 #1 Are there any rules for max. conduit size can be installed in concrete slab? Depending on slab thickness??? We used to limit conduit size at 2".
don_resqcapt19 Moderator Staff member Location Illinois Occupation retired electrician Oct 17, 2012 #2 That is not an electrical code issue. It is a building code or spec issue. Around here, they most often limit the OD of the conduit to less than 1/4 of the slab thickness.
