S7VEN
- Los Angeles, Ca
Hey everybody, have a general question about actual Loads on panels which might be stupid for some..
ex: what is the maximum amp load you can have on a 100 amp panel?
can you max out a residential panel carrying an actual 100 amp load for long periods of time?
or because it is also on a ocpd from the utility company you can only carry 80 amps max (80%) for long periods of time?
being that you can size a panel for over 100 amps, since everything won't be in use at the same time, can it's realistic full load be 100 amps? as in 100 amp reading with a meter
thanks
thanks
