newservice
- Syracuse NY
- Electrician extraordinaire
The spec sheet under the acrhitectural specs for Kiddie states :
"A maximum of 24 Kidde devices can be interconnected in a multiple station arrangement. The interconnect system must not exceed the NFPA (National Fire Protection Association) limit of 18
initiation devices, of which 12 can be smoke alarms. With 18 initiating devices (smoke, heat, CO, etc.), interconnected, it is still possible to interconnect 6 strobe lights and or relay modules."
Then, under the specs, the following:
"Interconnects: Up to 24 Kidde devices".
Where can this NFPA limit of 12 smokes be found? That doesn't seem like alot, are combinations included? Just wondering if someones dug into this maybe. If 12 is the limit, what can I do to get more? Run another circuit with an interconnected signal wire? :jawdrop:
