Max Number of outlets?
mwdkmpr
Is the maximum number of outlets that can be placed on a general purpose branch circuit or small appliance branch circuit specified? If yes, please give the code reference.
Thanks,
Mike
G
Guest
Guest
Re: Max Number of outlets?
Commercial or residential?
What kind of usage?
tom baker
Bremerton, Washington
Master Electrician
The residential receptacles are figured as part of the unit electrical load at 3 Watts per square foot. Section 220.3(B)(10) Commercial is determined at 180 VA per strap, with demand applied above 10 KVA. This typically works out to 12 receptacles for a 20A circuit
These are minimums and may not be sufficient for the application. I usually follow the commercial requirements for dwelling units.
mwdkmpr
I was asking about residential. The reason I asked is that if you take the 3VA/SFT and also the requirements for where outlets shall be placed, you end up hanging a lot of outlets on a circuit.
electricmanscott
Boston, MA
The requirement for so many outlets is to reduce the use of extnsion cords that can be a hazard. It is not likely that all of the receptacles will be loaded up.
pierre
Scott has the idea down pat, it is a safety issue, not a design issue as far as the NEC is concerned. If you are concerned, you can add as many circuits as you like :) .
Pierre
