LarryFine said:
So, what's the conclusion? Is or is not the quantity of receptacles on a circuit limited?
Quantity of plugs per circuit ?
No, Unlimited
Quantity of circuits per square foot ?
Yes, limits on the minimum number
And the reasoning behind it is this.
Home owners don't make purchases based on the number of receptacles in their house. They don't look around the room and say, "We have three more receptacles in the room that don't have anything plugged into them, so let's go buy three more things."
Usually the exact
opposite is true. They buy whatever they want and just plug in splitters and extension cords if there aren't enough receptacles for everything they've bought.
So the load in the house has nothing to do with the number of receptacles. The minimum receptacle spacing of 210.52(A)(1), 210.52(A)(2)(1), and 210.52(C)(1) is intended to limit
extension cords, not establish load. If you add receptacles, that doesn't mean that you're adding load.
I've never met a person that has looked at an unused receptacle and said, "Hey there's a plug that I'm not using, let's buy another TV to plug in." They fill up their house with stuff according to the sq'
size of the house.
General use receptacle load is covered by 220.14(J). If the code panel thinks that the usual modern home load is increasing because of the increase in electronics and other modern gadgets, they will make a change in 220.14(J) and/or make a change in Table220.12.
If you voluntarily increase the
density of the receptacles within the same square footage beyond what is required in 210.52, you
decrease the percentage of receptacles being used, but the load stays the
same. An increased density decreases the chance of splitters or extension cords being used, which is a very good thing.
If the customer can increase the receptacle density
and also afford to pay for more home runs and breakers, that's the best scenario. But if they increase the density without being able to afford more circuits, it's still
better to have more plugs than to have more splitters & cords.
David
