Max power over IP
m sleem
Top-notch Сasual Dating - Real-life Females
Usa
Health
What is the largest IP switch in terms of power kva?
I have been told that 1500 va is the max power can be delivered by the switch.
Dsg319
West Virginia
Wv Master “lectrician”
Quick google search I found one around 1440watts and about 6000$🫣. As far as the absolute maximum I am not sure.
AdrianWint
Midlands, UK
I guess that must depend on the number of ports the switch has...
There is a maximum per port defined in the standard (between 30 & 100W depending on which PoE standards are implemented), so the maximum for the switch is simply the max per port times the number of ports.
30W x 48 ports = 1440 Watts :)
grich
MP89.5, Mason City Subdivision
Broadcast Engineer
The amount is totally dependent upon the model of the switch. For example, certain Cisco models have a total PoE power budget that can be more if you have dual power supplies, or feed those supplies 208 or 240V instead of 120V.
m sleem
Usa
Health
Well, a cisco 9400 10 slot chassis will let you run 260 ports at 90w poe concurrently so a bit over 23kw. $50-60k for a refurb.
23kw is a very large switch similar to a power panel
A days ago, I've met a supplier from German offering lighting fixtures getting the power thru ethernet cables with full IP lighting control
