I've had 3 different responses from the manufacturer and from the sales/design group of a solar wholesaler. The question is simple.
Solaredge 7600a-us inverter
24 soleredge optimizers P400
24 Astroenergy 310W modules ( 2 strings of 12 )
Combiner Box
Solaredge states max string length of 25 optimizers on an inverter
?? Does the combiner make 2 strings of 12 into 1 string of 24??
I want to add 2 more modules to each string. The last answer was in a chat line to Solaredge. Answer, "Yes you can as long as the wire length is less than 1000 feet. But, you should call another number XXX-XXXX to make sure. My second answer was, "We can't advise on design." That came from the number the chatter provided. The third, "Here's a quote but we're not sure, you'll have to call Solaredge."
Combiner Box
