Installed a glass chandelier.
It did not have a canopy kit.
The chain was on a hook.
Installed box and used a Home Depot lowes canopy kit.
http://m.lowes.com/pd/Portfolio-Aged-Brass-Lamp-Canopy-Kit/3659354
Bracket goes to box. Two screws come thru the bracket thru plate with two nuts to secure plate. Eye hook mounts to plate.
Looks like the screws and nuts are 8 32 ?? But thinner ?? Cheap Chinese metal
Trying to search how much weight that kit will hold
The only info I can locate is that it's mentioned that the box supported to framing should be rated for fifty pounds.
Should I assume that they would make this canopy rated for fifty pounds if they mention that in the directions on the packing.
I hate to assume.
Thank you.
Let me add one more question.
I had to get creative installing the box in a peak of a ceiling and using some wood and deep round to get it low enough for this canopy.
I had a regular depth round and an extension round on the truck which would have been close to the depth needed. I opted for the wood and deep box. May not be the smartest thing to use an extension box for a chandelier but is there any articles against using one ? Just wondering.
Little nervous about the canopy. I feel good the way it is. But. I think there maybe be extra glass added to it.
Was my aunts. The home owner is my cousin. If it comes down I won't hear the end of it :- ).
Watch those feeler bits. I picked up a 54" long x 1/2 inch to go thru several roof joists.
I thought I could bend it enough to get it to go straight across from the bed room to an attic area.
Turns out. It went up a bit on an angle and went thru the gap that's left at the peak of the roof for roof venting and lifted up some peak shingles which I had to lay back down nail and tar. (We're talking way up there) Rains coming so I hope no leaks and the light stays up.
Geez.
I hate to assume.
Thank you.
Geez.
