I have a situation where due to voltage drop I need to upsize cable and terminate #6 wire on a 15A breaker in a 120/208V panelboard. I may be able to reduce to #8 and still be ok with VD.
What is typically maximum permissible or feasible wire size that can be terminated on a 15A breaker? Load is actually only about 5A and individually fused at load location so it is possible to increase breaker size to accomadate required wire size to account for voltage drop.
Curious to hear from others what the common approach here is.
