jmoore284@gmail.com
- Evansville, IN
According to 110.24 service equipment is required to be marked with the maximum available fault equipment. Downstream devices such as MCC's shall have their maximum available fault current documented but marking is not required.
I am looking to perform a short circuit study for a client in which I will determine the maximum available fault current throughout their power system. The plan is to then apply labels to each distribution device (MCC's, PDP's, breaker panels, etc.) identifying the maximum available fault current and the date of the calculation. I will also provide a report listing each devices maximum available fault current as well as it's withstand or SCCR rating.
The idea of labeling each distribution device with its max AFC is to make it easier on contractors to properly size new equipment they are installing to ensure their properly rated for the fault current at that point.
Has anyone labeled or seen labels like this? I'm also curious of everyone's thoughts on the idea.
