A friend of mine teaches a code class, and he is claiming it states somewhere in the code that 100 ft is the max. We were @ work, and I threw the book at him and told him to show me. He could not find it at the time, and now I am very curious!!
CH 9 Table 1 said:FPN No. 1: Table 1 is based on common conditions of
proper cabling and alignment of conductors where the
length of the pull and the number of bends are within reasonable
limits. It should be recognized that, for certain conditions,
a larger size conduit or a lesser conduit fill should
be considered.
Wow. . I wonder where he thought he was seeing this stuff. . lol
There's a lot of 'urban legends' that seem to never die, and no one knows where they come from.
No wire nuts in a panel.... ground rods at light pole bases... ground up/down.... no reusing old equipment... and, like this thread, 100' max pipe run.
They simply will not die.
I believe if you pull a ground wire, it doesn't matter what the condition of the conduit is, there is low resistance path to facilitate the action of the OCPD.
EMT is not the magical path for 250.118 if other provisions are used. I would be comfortable pulling a quarter mile if neccesary, and allowable per the wire/cable manufacturer's call outs for their conductor(s).
Kill the urban legends!
Perhaps not magical,.. just one that offers a lower impedance
This is a great document. I have used the tables that were first developed at the Georgia Tech by Dr. Sakis Meliopoulos. Dick Loyd was also involved with the setting up and testing to get the results that are published in this book. I think the biggest surprises for me was that the largest fault current return was always very close to the circuit conductors even when multiple paths were available and that most of the current flowed on the conduit when a grounding conductor was in the conduit.
I am not so sure I agree with that statement, my common sense alarm just went off. I do agree that the 'extra' grounding conductor is a good idea. :smile:. . . if you pull a ground wire, it doesn't matter what the condition of the conduit is. . .
I hope he has not been teaching this "rule"
