Delta 3
- Memphis, TN
Does anyone know if there is a limit on how many (within reason) receptacles can be put on the load side of a GFCI receptacle?
Delta 3 said:Does anyone know if there is a limit on how many (within reason) receptacles can be put on the load side of a GFCI receptacle?
bphgravity said:Just be aware that the potential number of inconvenient / nuisance trips is directly proportional to the number of receptacles served by one gfci device.
bkludecke said:Most of the GFCI devices we use are listed for 20amps feed through - same as the branch circuit - so as long as you can't overload it I don't see where it matters how many receptacles are down stream of it. Same as if it were a GFCI c/b.
iwire said:The most reliable way to deal with this is to use a GFCI receptacle at each point of use. Many of the plans we get specify that we do just that.
This also makes it easy for reseting the GFCI if it trips, no hunting for it's location.
peter d said:I'd just like to point out that this is almost never done in residential, obviously due to cost.
I agree Iwire and that's how I did my house and that's how I do custom homes when $$ permit. But the question was about outlets/recepts and if care is given when making the terminations and laying out the circuit, few problems - if any - are likely to occur. We've done thousands of feed-through applications without nuisance trips and I attribute it to using care and common sense when laying out the circuit. We never loop bathroom recepts anymore, and kitchen are getting 3+ SA cicuits in the larger homes.iwire said:As far as circuit current it does not make much difference.
As far as a ground fault trip it does make a difference.
Every appliance and every foot of wiring on the load side of the GFCI adds to the amount of current imbalance the GFCI reads.
If you had 5 appliances on the circuit each one adding half a ma of leakage current onto the circuit you would be getting close to trip without any real ground fault.
racerdave3 said:No limit that I am aware of. I think every electrician pretty much uses common sense on the number of receptacles on a circuit anyway.
allenwayne said:That is a very broad statement, I let another guy go into a house I was doing when I fell ill.When I returned in a few days I went through what was done while out.I found over 35 receptacles on a circuit That I had pulled a HR for.When i asked him what he was thinking he simply responded I wired that circuit till I got tired. GRRRRRRRRRRRRR !!!!!!!!! lost a few hours redoing things on that one.
curt_bixel@yahoo.com said:Considering that the plastic inserts are easily removed by a child, is a GFCI sufficient protection for small children.
I know that there are outlets available that have built in protection,
