I switched it for the M18 hole hog and it worked good. Only thing was you couldn't use the foot pedal trigger to power up, had to use the hand trigger. Used on a 280 ft pull. In fact it worked so good the guy on the feed end couldn't keep up.I have a maxius tugger 3k. Couple of pulls coming up of around 200' no power available unless I load my generator. Anybody have comments on using the battery hole hawg on these tuggers
