jrannis said:For some reason I thought it was 500'.
don_resqcapt19 said:There is also a limit based on the pulling calculations. It does no good to pull on the conductor with so much force that it breaks, or that you crush the inslulation as a result of excessive sidewall pressure when pulling around bends.
Don
Okay, now your jet line is three miles away. Now what are you going to do? Got three miles of pull rope and a Caterpillar tugger?Rockyd said:Air compressor - High CFM? Check.
Bucket of Jetline? Check.
"Stand clear the gear!"
DISTANCE UNLIMITED!
I guess, but your average electrical contractor doesn't have the Hogg-Davis puller that they use when they string up those pole lines. I'm not sure what the pulling capability on those is, but I'm sure it's in the 10's of thousands of pounds.Rockyd said:Come on Marc...No such thing as an impossible pull....
sounds like a fun day. long pulls with those large conductors are never easy no matter how many pullers are set uproger said:I have been in on 800' + pulls of 600 kcmil in conduit, and 2,000' runs of 500 kcmil 4 conductor with ground MV cable in cable tray.
We had multiple tuggers rigged for these particular MV pulls.
I have used tuggers, pick up trucks, diggers, line trucks, backhoes, trackhoes, and cranes to make pulls, what ever it takes.
Roger
