hcecabigdog
OK, last one for the night. How many jurisdictions are approving this wiring method. Baltimore county is not. Reason being we don't allow aluminum wiring less than #6. The bonding "conductor" in this cabble is #14- #10.
hcecabigdog said:OK, last one for the night. How many jurisdictions are approving this wiring method. Baltimore county is not. Reason being we don't allow aluminum wiring less than #6. The bonding "conductor" in this cabble is #14- #10.
It's not a conductor.iwire said:This is the first time I have seen anyone post that.
hcecabigdog said:Thanks for the help. Again it's not my decision. I only enforce the code. AC cable is listed with a bonding strap. MCap is a conductor
iwire said:Testing shows that MCap has a lower grounding impedance then MC with a copper ground so basically the areas that prohibit MCap are being very stupid.
peter d said:I would assume this is because of the aluminum bonding conductor that is basically in parallel with and bonding together the armor spirals, no?
jimport said:It all goes back to the bond being called a conductor by Southwire. If they were to call it a bond strip it would be ok to use.
Just another example where the words as written can change things.
