MC-ap Duplex Connector
According to the UL Database this specific MC connector is suitable for use with MC interlocking aluminum armor ground cable with a diameter of .600 only.
Chris
This is from the Topaz #350 spec sheet:
Features
• Fits aluminum smooth extruded MC range .210-.500
• Indoor use only
• Suitable for: #14-2 through #12-3 wire with ground NM sheathed cable,
#14-2 wire steel armored cable, #14-2 wire with ground aluminum
armored cable, 3/8" FMC, aluminum smooth sheath metal clad cable
0.410-0.500" diameter aluminum interlocked metal clad cable
0.460-0.538" diameter, steel interlocked metal clad cable
0.438-0.560" diameter
• 3/8" size fits 1/2" knockout
Applications
• In a dry location, use to connect two pieces of flexible metallic
conduit, AC, MC, or NM sheathed cable, to a steel outlet box or
other metal enclosure when using only one knockout opening
Standard Material
• Zinc
