I need to run 4 200 Amp 120/240 Panels in a building that requires either the SER to be completely covered by Sheetrock or use metallic cable.
Question is, Is 2/0 CU MC Cable acceptable for Feeders?? My concern is that the Grounding conductor is only a #6, don't I need a #4 or is the combination of sheathing and grounding conductor make up for the #4 or is #6 sufficient?
Thank You,
Kris Quinn QEC
Thank You,
Kris Quinn QEC
