hello there everyone. new to the forum been reading for about a month enjoy the site tremendously. ok so im running a big box store remodel, we are installing the cash register power poles each power pole is fed with two circuits. circuit 1 is from panel A, circuit 2 is from panel B. panel a is 120/240 single phase (u.p.s. protected) panel b is 120/208 three phase (normal panel) both circuits 120 volt 20 amp. panels are fed from different locations and different transformers which eventually come from the same m.d.p. the factory supplied 3/8s flex whips coming from the power pole go to the same 4 square box and terminate to the box using a double mc connector locknut set screw type. the arguement is with one of my journeymen whom claims that that is a violation because the are fed from two seperate power sources. i say not a violation. i told him to show me (its a test) his reasoning is sound but i dont see a problem with it how bout you fellows. thanks for the unobjective oppinion.
Chris Reschke
Master Electrician
Memphis, Michigan (40 miles north of the motor city)
Chris Reschke
Master Electrician
