MC Cable Labor
Alwayslearningelec
NJ
Estimator
12/2 MC Steel Armor w/ supports and connectors
Generally speaking here regarding install . Me and a friend have pretty different labor units per thousand.
Standard height ceiling, ceiling not installed yet.
Supported either a bridle ring on flange, or KX clip on rod by others.
500' with 15 connectors.
I use about 18 hours and he uses about 10 hours. Thoughts??
By standard height are we to assume ladder work? With 15 connectors you are stopping off at 7-8 junction boxes? Wall or ceiling? Does your labor include making up connections in those boxes?
I show 12/2 MC at .022/ft or 22 hrs per thousand
Yes, ladder work and stopping at 7-8 4" boxes in ceiling. Labor does NOT include the boxes or splices within.
I don't use programs to determine my cost. I basically give each process a labor unit . 15min - 30 min - 1/2 hr ect .. then I give every aspect a value.
let's say 7 boxes ÷ 500ft .. roughly 71ft.
figure how long is it going to take to run a cable 75 ft strap it 20 times mount the box make up splices. then multiply by 7 boxes.
anywhere from 1 to 2 hrs per box.
depending on simple variables.
1 hour is alot of time in that type of work.
That's exactly where my mind was going. 10-12 hours should cover that portion of work.
Better foreman?
