zemingduan
- Philadelphia,PA
- Electrical Designer
Hi, guys. I'm an electrical designer, not an electrician, and not familiar with the wiring method. The architect is asking these two questions below for a delicate historical building. They want to know what they’re dealing with.
"We plan to cut a channel in the existing plaster/brick walls, install the wire to some new light fixtures, then patch the channel with plaster to hide the wire. Is MC cable used, or conduit per NEC? We want to know what we’re dealing with and the dimension of the wires "
What is the required/usual dimension of the channel (depth and width) for one 20AMP lighting branch circuit?
"A final question has to do with the junction boxes at our surface mounted lights that are channeled into the plaster. This applies primarily to exit signs and emergency lights. Do these need to be full depth boxes, or can they be shallow boxes? What size will these boxes be?"
Can anyone give me some help? Appreciate it!
