Part II. Installation
330.10 Uses Permitted. 330.10(A) General Uses.
Type MC cable shall be permitted as follows:
(1) For services, feeders, and branch circuits.
(2) For power, lighting, control, and signal circuits.
(3) Indoors or outdoors.
(4)Exposed or concealed.
(5)To be direct buried where identified for such use.
(6)In cable tray where identified for such use.
(7)In any raceway.
(8)As aerial cable on a messenger.
(9)In hazardous (classified) locations where specifically permitted by other articles in this Code.
(10)In dry locations and embedded in plaster finish on brick or other masonry except in damp or wet locations.
(11)In wet locations where a corrosion-resistant jacket is provided over the metallic covering and any of the following conditions are met:
a. The metallic covering is impervious to moisture.
b. A jacket resistant to moisture is provided under the metal covering.
c. The insulated conductors under the metallic covering are listed for use in wet locations.
(12)Where single-conductor cables are used, all phase conductors and, where used, the grounded conductor shall be grouped together to minimize induced voltage on the sheath.
