boris machado
does the code prohibit to bundle up various mc cables together my inspector said induction creates heat that could damage de wires
310.15 Ampacities for Conductors Rated 0?2000 Volts.
(A) General.
(2) Selection of Ampacity. Where more than one calculated or tabulated ampacity could apply for a given circuit length, the lowest value shall be used.
Exception: Where two different ampacities apply to adjacent portions of a circuit, the higher ampacity shall be permitted to be used beyond the point of transition, a distance equal to 3.0 m (10 ft) or 10 percent of the circuit length figured at the higher ampacity, whichever is less.
I wouldn't say that bundling MC cable isn't in a workman like manner. In fact it's just the opposite. I've seen many jobs where the cable looks like spaghetti entering the panel. Those of us who take the time to carefully trim out the cables and dress them together are going the extra mile to perform in a workman like manner.What is 110 something a neat and workman type manner.bundle the mc up and shove it down the wall to the panel to me does not comply spread them out and run them neatly to the panel does. but it is behind the drywall and no one will ever see it. take a little pride in your work even if you are the only one that does see it you will feel better just knowing you did a good job.
In addition, like seatbelt and helmet laws, it should not even be needed.Originally posted by peter d:
Bottom line, "neat and workmanlike" is so vague and subjective that it should be removed from the code.
Wow, this brings up a question.Originally posted by ryan_618:
The exception that most people don't consider is this one, which often times nullifies the whole thing:
(A) General.
