Alwayslearningelec
- NJ
- Estimator
Why the heck would you drill ko? Wouldn't a concentric ko be there and just punch out?Yes but they're terrible to remove if you have a need to take them back out. Also they're not great if the sparky is drilling the KO's with a hole saw where the hole might be slightly larger than a standard KO.
Many boxes, wireways, and panel enclosures have no factory KO's and are field drilled or punched. We always ordered our panel back boxes, wireways, and screw cover boxes with no knock outs.Why the heck would you drill ko? Wouldn't a concentric ko be there and just punch out?
Device boxes? So which connector would you rather use? Also, mostly insulated throat?Many boxes, wireways, and panel enclosures have no factory KO's and are field drilled or punched. We always ordered our panel back boxes, wireways, and screw cover boxes with no knock outs.
I prefer the connectors with a locknut. Insulated throat I don't like.Device boxes? So which connector would you rather use? Also, mostly insulated throat?
Spec usually call for them, I think. is that what "redheads" are?I prefer the connectors with a locknut. Insulated throat I don't like.
They are they make hospital grade snap ins too. Arlington has them they have a purple tinge and longer body.I don't see how the snap ins are listed for AC cable which in that case it is part of the EGC. Snap one of those in a concentric and what kind of EGC do you have? I'll stick with locknuts
I dispute that they are that difficult to remove, if you have experience and a small tweaker screwdriver.Yes but they're terrible to remove if you have a need to take them back out. Also they're not great if the sparky is drilling the KO's with a hole saw where the hole might be slightly larger than a standard KO.
Yes, but you need the snap in type like the 3810 of the 3810 AST
Dispute all you want, they are difficult to remove.I dispute that they are that difficult to remove, if you have experience and a small tweaker screwdriver.
I'm not saying you have difficulty, I am saying I don't.Dispute all you want, they are difficult to remove.
More power to you!I'm not saying you have difficulty, I am saying I don't.
