AKElectrician
- Soldotna, AK, USA
First I have done just about every combo of MC-HL to whatever type of box or fitting "cause that's how you do it". Second I personally feel MC-HL is the highest abused product for code violations I have ever worked with, and no matter what you do unless you hide it in conduit this stuff looks sloppy 30 mins after your done making it look good and someone/wind/gravity bumps it. Third I feel that "roping" refineries and gas fields is killing off lots of conduit workmanship/knowledge. I personally have met multiple journeyman who have only made nipples and installed them, that's the extent of there conduit running, but man can they run some cable.
To the point, I can not find anywhere saying anything that conduit hubs, unions, condulet's, or other fittings are acceptable with anything other than heavy wall conduit or EMT if listed. The main combos typically done in the field are Meyers Hubs with TMC/TMC-X, UNY/UNL with TMC/TMC-X, or GUA/ L-fittings to TMC/TMCX, TMC/TMCX to couplings/RE's, also supported with straps that say on them RMC/IMC/EMT. All the classified conduit fittings are listed to be used with heavy wall conduit only as far as I can find, unless I missed something. I have been wrong thousands of times not afraid of being wrong again. I understand the whole AHJ thing, but this has become standard where I live, and have seen it done and done it everywhere whether the AHJ knows it's done or not. I also understand that most MC-HL installations would be hideous if we followed the rules to the T. But MC-HL as written by most manufacturers is to replace conduit all together cause this product is "faster,and superior to conduit". Now this may seem like a stupid question to be asking and I should just be a good copy cat and follow suit cause it works and is cheaper and faster, but with that thought process why not cut corners everywhere and install whatever works out to be easier code compliant or not. IF i am reading into this right basically two clearly classified fittings are being installed together, that have not been "tested" together. Is it unsafe? I doubt it but IF I am right it is quite the code violation in my mind. How many guys been busted using some cheap part somewhere that worked and was safe and just as good as the other cheap part they were supposed to use, but wasn't listed and they had to go back and redo all their hard work?
