We use a lot of MC Quik Lite with my current job. We make sure to use MCI-A rated connectors. This is the style of MC that has the internal aluminum wire running down the length of the cable; it does not have a separate ground wire.
One of my journeymen is unhappy because the rough-in crew used this stuff for a wall heater and there was nothing for the wall heater can to ground to. The only bond was via the cable connector.
I also just learned today that some of the electricians are using MC Quik Lite into our sub-panels and landing the aluminum bonding wire into the ground bar. <--- this part makes me cringe.
However, I think all of the above is technically to code.
Can you help see any blind spots I'm overlooking? Is there a technical reason I need to be using regular MC for devices other than receptacles - and also sub-panels? I mean the latter is something I would open up and think amateurs did it.
