We are in the process of becoming 70E compliant. Currently an ARC-Flash analysis has been done and all our MCC's have been labeled with the IE @ 18Inches and the required PPE. This label is based on the MCC bus fault current and the MCC main-feeder breaker clearing times.
Should this same PPE level be worn when working in a MCC bucket (disconnect on or off) since the load side of the breaker is still energized?
Thanks
Thanks
