kriverswaters
I have an application where we are feeding a Nema 3, (external), 480 Volt, 250 Amp, Motor Control Center from a 600 Amp, 480\277 Volt Panel. The new MCC is going to be physically located external from the warehouse, and not in view, where the existing 480 Volt, 600 Amp panel is located. The new MCC does not have a main breaker or disconnect. Does the NEC require that a main disconnect, (400 Amp), be installed next to the MCC?
