adityalagudu
- victoria,TX,USA
What type of MCC dual CB feeder bucket is required to feed 480V, 2A, 14 LRA, 1HP motor? Also need 3 pole fuse. What is purpose of using fuse and circuit breaker at the same time?
Don’t thank me but wait for experts as I am just a student on here trying to learn... I really need to get a signature that says that...That sounds reasonable.
Thank you.
So assuming that since you are saying "feeder bucket", the motor controller is at the machine, not the MCC so you are only wanting a feeder. If that's the case, the minimum feeder conductor size is 14ga, so you would use a 15A feeder breaker in the bucket.What type of MCC dual CB feeder bucket is required to feed 480V, 2A, 14 LRA, 1HP motor? Also need 3 pole fuse. What is purpose of using fuse and circuit breaker at the same time?
