Electrogrunt
- Oakland,CA
At the facility I work at, we just had one of the RVAT starters catch on fire. We are still not sure what drove this, but what happened is that as the transformer was cooking, it spread an acidic residue throughout the MCC, impregnating the insulating busbar supports with a semi conducting material. After my co worker and I found that the busbars had about 1/2 MOhm between them, we decided to tear the whole thing apart, and clean every thing. This involved about 18 hours of work until we got the resistance into the 50 Mohm range. Still not great, but we will change out these supports during our next shutdown. This residue also affected the plc rack, so that none of the I/O cards worked, and the outputs were sending signals to start, with no command. Our area manger tried valiantly, although vainly to resurrect these cards by pouring alcohol on them, and heating them over portable lights. We suggested that they wait until the programmers could be contacted in the morning, and it was not until then that a resolution was found; replace all of the I/O cards, as well as the main processor card. Has anyone seen something like this happen, and were you able to determine what caused it? Also, as this happened in the evening, it was the assistant plant Manager who opened the main disconnect, a gutsy move that probably prevented a more serious outcome.
