This may be an obvious answer but I have seen a lot of MCC's recently that had a main breaker rating which was less than the bus rating. For example a 400A main breaker on an 800A MCC. Or a 1000A breaker on a 2000A MCC.
I would think that if you had an 800A MCC, you would eventually maybe want to use its full capacity so why not make the main breaker an 800A breaker (Even though the current load calculation only called for 400A) If the feeders are protected by the upstream feeder breaker than the main breaker becomes somewhat irrelevant in terms of cable feeder protection anyway and is just there to protect the bus.
I'm thinking that maybe this is a cost thing, with people only wanting to pay for the bare minimum for what is needed at the time. Or maybe it has something to do with the different bus ratings of MCC's that are available since they are only available in certain increments. For instance even if you have a 400A load, the smallest MCC you can buy is 800A.
Just curios to hear others thoughts.
