The sawmill / pellet mill itself would be Class III, Div 1 if it's the manufacturing area, Div. 2 if it's a storage area. Most of the time, the MCC is put in another building so it is neither. There is no requirement for seals in conduits entering or exiting the area, but any j-boxes in the areas need to be dust tight: no NEMA 1 in other words. That doesn't mean it's not a good idea, so nothing is stopping you from sealing them. Read article 503 in detail, there are lots of issues to consider, but no sealing. Sealing is a Class I issue for the most part, or when something goes into or out of a Class I to a Class II or III area.
I spent 12 years in the Pacific North West working in numerous lumber, paper and pellet mills, sawdust is permanently embedded in my lung tissue. On one project where we put in a new MCC at an old mill, I had a similar concern strictly from a contamination standpoint, so I packed the conduits with duct seal compound just on general principals. The plant electrician saw me do that and said "What's that stuff?" Does that tell you something?
