Hello everyone,
I'm trying to understand how UL Rating works on this particular example. You got MCC built with VFDs, Starters and breakers inside, and it's UL Rated. Let say in a couple of years you need to replace one of the VFDs and you can not replace it with the same one because it's obsolete. If you put a different one inside do you lose UL rating of the MCC? I'm having with discussion with my boss, and my opinion is until the new one is UL rated you are good. His opinion is unless you replace it with the exactly the same you are loosing UL rating. How is this usually done in practice?
Thank you,
Nikola
Thank you,
Nikola
