Mehdi
- United States
- Electrical Engineer
10HP Motor name plate shows volts 230/460 -Amps 21.6/10.8. We requested 208V motor and manufacturer said it is compactable but due to some reason they can provide 208V/Amps information on motor name plate. We ran the motor on 208 and it was drawing 19.8 Amps. In the beginning of the project, we looked into NEC table and found 10hp motor full load amps 30.8 at 208 volts. we selected the breaker 30-42 amps. I was wondering why motor is taking same amps on 208 what are on nameplate for 230 volts. I was not sure if we met the UL508a and NEC code in a right direction. Kindly help me to understand and learn. Thank you.
