Re: Meaning of Electrical Rating
I had no idea I would get such an interested and kind-hearted response. Thanks to all of you. My wife?s lungs have very low capacity and the continuous flow oxygen supplied by the concentrator is much better for her than the puff oxygen supplied by the regulator attached to an oxygen tank. We are not wealthy, but cost is outweighed by other considerations.
About 6 years ago, we installed the first concentrator/nebulizer system in our 1996 Chevy truck. My son has a small fleet of trucks, and his mechanic installed the system. The mechanic is very conscientious, treats us like family, has considerable practical experience and almost no formal training. On the first system, the only thing I did was to research on the Internet about what inverter to use. I came with the Exeltech true sin-wave inverter, and we bought their highest power device, 1100 watts/2200 surge, the Exeltech XP1100 12V.
On the first system the mechanic left the standard alternator in place, and added a standard car battery connected to the inverter. He installed an isolator, which was supposed to separate the concentrator system from the truck starting system. We measured the concentrator, and its start-up draw is about 2 ? times its running draw. I suspect the nebulizer is about the same --- both are compressor-centered devices. This system was somewhat experimental; we wanted to find out if we could get something to work.
We have had at least two experiences with both batteries going dead. The alternator failed, and the local GM dealer replaced the 100 amp alternator with a 140 amp version. The original car type battery failed and we replaced it with a deep cycle D34 Optima. We have had two Optimas, each lasting about 2 years. The present configuration has worked quite well except for the short life of the Optimas. It has been very dependable once we made the alternator/battery upgrade.
In April 2004 I bought a new Chevrolet truck and want to set it up with a concentrator and nebulizer. This truck is still under an extended warranty. I intend to keep the old truck with its concentrator system as backup, but will be more comfortable with a newer vehicle as our main transportation. I have tried everywhere that I can think of to get someone with more training to do this work, and have ended up again with my son?s mechanic. No one could be more conscientious, or care more about us. The local GM dealer has also done his best to find an installer without success. We are in a small town in Southern Arizona, with the closest city being Tucson, 125 miles away. I am willing to take the truck to Tucson, but have found no one more qualified there either.
On the new system, in order to provide more emergency protection as well as better battery life, we have had a suggestion to use two deep cycle batteries in parallel. We have ordered two Optima D31As, each rated at 75 Amp Hours versus the 55 AH of the D34. We have purchased another Exeltech 1100. We have a new concentrator rated at 4.3 amps versus the old concentrator?s 5 amps. The new truck presently has a 105 amp stock alternator. GM has a 145 amp version which is used on 4 wheel drive versions of our truck and the GM rep our dealer has contacted feels this would be enough increase in output, and would be certain not to damage the truck?s electrical system. I think it is likely that the 2004 truck has much more delicate electronics than the 1996.
Thanks again to everyone for your interest and help.
