measuring device for KO's center .
Gaston
Hi there fellows, I'm addressing to any one that may have an idea of where I can find a tool that , ( looks like a ruler )It's for measuring the center of the pilot hole for any size KO's . This tool is very handy when doing lots of KO's on a gutter or equipment boxes at the same time that you can mix and match sizes based on your needs .I have seen in display, but am not able to find it now a days . Again, this may not have been made by any of the common manufacturers , but I can assure you I have seen it .
I'll be very thankful to hear from you even if it turns out to be something different but at the same time useful.
Thank you.
Gaston.:wink:
Thank you!
Thank you!
Thanks guys ! that was quick!!!!!!! It is the one I was looking for, I'll post my results next week since I'll need it on monday, you will hear from me soon .
Thank you .
Gaston.
have not been able to use the tool......
:confused:
Well guys , I found the tool and it was not as expensive as thought it would be but I had no chance to use it so far .All of the openings I had in mind had to be measured by placing he disconect under the gutter and marking the circunference of the 2" connector because I had already installed it , high enough to not need to use a measuring tool, instead , I used the disconnect it self and it beat my intentions . I'd like to thank you for responding and I will get back as soon as I get a real chance to use my new found tool!!!!!!!:cool:
