Re: Mechanical Continuity
Nick, can you think of any other indoor electric equipment that is not totally enclosed and raceways enter without connectors?
I not saying this is bad or dangerous or that the code needs changing, it is just different from anything else we do.
Could I come into the top of the switch gear with PVC through a tight hole a few inches and just put on a flare end?
I think I would be cited for 300.12 Mechanical continuity, even if I had it supported as close as possible to the switch gear.
How about a typical transformer can I come up through the slab into the bottom of it with out a connector?
I had 2 - 4" PVCs coming in through a foundation wall that we needed to put a pull can on so we chiseled out the cement in order to get connectors on them to enter the can. Could I have just stubbed them into the back of the can and put a flare end on in the can?
This is no big deal to me, but with everything that's in the code I am surprised there is not a reference to this.
If there is a code reference to it could someone steer me to it?
