john37
- Riverside, California
I have a project going on right now where the general contractor is questioning who takes care of the connection from the disconnect to the air handling unit. It has always been my understanding that the Electrician provides power up to the disconnect and then from the disconnect make the power (120V or 480V) connection to the unit itself. Am I correct in this assumption? Evidentially the Mechanical specs says something about the wiring but the general contractor is stating it does not say "low voltage" wiring. In my opinion the Mechanical contractor is not an Electrician so he should not be required to connect any connections that are not with the exception of low voltage control wiring. Any opinions is appreciated.
