Hi,
I've been doing some commercial building design lately and would like to check something with you guys.
My question relates to panelboard loading derived from from mechanical equipment.
Of course, I size motor conductors and breakers based on FLA and other rules, which are fairly straightforward. But it seems to me that resultant load on a distribution panel load is subject to some interpretation and judgment, with factors like actual motor load and duty cycle becoming very important.
For example, I have a bunch of 2.5 hp hydraulic engine hoists in this one building (a car dealership), each on a separate 25A circuit, sized based on FLA. If each pump were fully loaded and running all the time then the load on the panel is a bit less than 2KW load to the panel, for a total of something like 7.5KW. But, they run very intermittently, with a duty cycle well under 10%, so the total average load on the panel is actually much less. Based on duty cycle alone I think a value of 600W each is reasonable. I understand that it is important to design for worse case peak loads, but I tend to leave some capacity in each panel for that purpose.
I realize in this case the motors are fairly small - I am interested in the process rather than this particular example. The same sorts of decisions apply to larger mechanical equipment like HVAC systems. Perhaps some of you take a very conservative approach and just apply the full KW rating?
thanks!
thanks!
