Is this for periodic maintenance or trouble shooting operational issues? Sometime a lock out tag out involves more than one craft group to verify a piece of equipment safe to enter or be worked on.
I suspect she means for both. PM is usually but not always post-lockout. TS is usually but not always pre-lockout. So it would apply to both.
You would not say some lights went out so the power must be off, and a test start after a lockout is not a pathetic test, it is one of many steps to prove the equipment is out of service.
Just my opinion of a test start since virtually everything disables that. But not everything disables the manual functions which are just as important. Putting the mode in manual and trying to move an axis is better but still weak.
And yes, I would much rather observe that my processor power lights went out, my hydraulic pumps shut off, and my pneumatic feed solenoid popped for lockout than believe its down because the start button doesn't work.
Your procedure would be; to perform an orderly shutdown of the machinery you would test for no power, test your meter first on a known live source, test equipment dead then test your meter on a known live source again, to make sure your test equipment is still operational. They do fail at the wrong time. Pull fuses, or remove conductors from an ACB for a visible break.
Live-Dead-Live is great when you're an electrician planning to work on the wires. This question includes pipefitters planning to work on filtration as well. They don't get meters and we don't let them pull fuses. Hence back to the LOTO placard where someone has gone specifically through that machine to determine a way to verify the energy is locked out without resorting to trade specific tools.
Then you can operate your emergency stops that should be lockable in the emergency off position.
Why? Operating the Estops is for emergency use or for inspecting the Estop functions; not typically for locking out a machine. And yes I know they CAN be used for such but most systems have lockable disconnects and/or valves that are much more secure.
When you get to the mechanical portion ... In Example a liquid pump ... In the case of hydraulics ...
Which again is back to the "Knowledgeable person writing up the lockout placard" for the specific machine.
You always try to operate the equipment after all these steps are used to insure the prints are not wrong or panels mislabeled.
Always? Once you verify the energy is dead to the subsystem you are working on there is no need to try and operate the machine. If I lock out the coolant lines to my filters and verify, then I can safely change them. If I start the machine with the coolant locked out then I might damage the machine needlessly. Not everything has to be shut down for every service call.
Some of these spaces inside machinery can also be classified as a confined space where retrieval equipment would be needed.
Or vented, or tested for air quality.
Also using lockable devices and tags on all valves, disconnect switches, breakers, start buttons, emergency stops and whatever else needs to be done to insure that your workers and yourself climbing inside a piece of machinery go home at the end of the shift the way they came into work. What price do you put on yourself or others in the name of safety?
Electric Pete
Holy smoke! Lockables on ALL valves, devices, disconnects, breakers, starts, Estops, and more? No way! I'll do things for the sake of safety but not for its name. I don't need a lockout on every Estop since locking out one affects them all. Additional lock points for Estops would be a waste of money providing NO safety improvement. And if my lockout procedure calls for locking the main disconnect then I don't need any locks for Estops.
And as to that infamous price for safety: I won't pay to save one person on their death bed with the lives of several healthy people. So there is a price. We just haven't established it yet.
