I'm installing a Leviton Meter Combo, LP820-RMC. This 200 amp panel has feed through lugs that I'm using to feed an indoor 200 amp panel with 4/0 SER that's about 25' away. The issue I'm having is that the Neutral feed though that's provided with this panel will accept 2/0 and my neutral conductor is 4/0. I've looked at getting an offset pin reducer/pin terminal but those are really hard to come by in this size. I don't need 4/0 for my neutral - but that's what's available with the SER.
Can I use a double port mechanical lug that I attach to the panel?
I would use 2/0 Cu from the panels include feed through lug to one port on the mechanical lug and then use the other port (or whatever they're called) for the 4/0 Al that goes to the sub panel.
Does this sound like a good plan? I've looked, and looked and looked for a 4/0 lug kit that has side entry (because there's no enough space for proper wire bend radius otherwise) and I can't find anyone that has anything in stock.
Thanks for the help.
