mstrlucky74
- NJ
Curious as to which conduit others would price/install inthis situation.
Spec reads:
RGS in the following locations:
Raceways run within 8feet of the finished floor in garage areas,
loading docks, elevatormachine rooms, mechanical rooms over
900 square feet, andelsewhere where subject to mechanical
damage.
Two questions:
1. “Where subject to mechanical damage”. Would you consideran entire mechanical room subject to mechanical damage?
2. If you have a motor on the ground being fed from a panelacross the room(in mechanical space) technically you have a few feet at thepanel and motor that are within 8’ of finished floor. Would you put the entirerun in RGS, EMT or change over from EMT to RGS within 8’ of floor?
The subject o mechanical damage is so vague? Where exactly would those areas be?
Thanks.
Spec reads:
damage.
Two questions:
Thanks.
