knot stable
- Warren,RI
I have a customer whos home I'm wiring and he asked me for media access in the bedrooms. Is this RG6 Quad and a cat6 jack? Any input?
Traditionally, that means two coaxes and two CAT-5's, but I'm not a believe in a one-size-fits-all kind of system. It depends on what he wants; one four-outlet box and plate per room may be too much or too little.I have a customer whos home I'm wiring and he asked me for media access in the bedrooms. Is this RG6 Quad and a cat6 jack? Any input?
Central vacuum tube is a lot more cost effective, and gives you a 2" smooth tube for pulling cables through. We install 2 - 2" Central vac tubes from attic to basement, 1 for the cables being installed and 1 for future use. Then I use a 3/4" emt stub into the attic / basement with a plastic pipe collar, nailed to a stud. Very cheap and allows easy access for cables anywhere.
Which section in Chapter 3 covers using vacuum tube as a raceway?
What section of the nec prohibits it?
See 800.110, 820.110 ('08 NEC).
