sanders11
- Louisville, KY
I have been told that when running shielded 5kV EPR MV-105 cable, (3) shielded separate conductors, in conduit that it is normal practice that the grounding conductor only has to be a 600V insulated conductor. Is this true? Is it normal practice to use a 600V insulated conductor as a ground conductor in a medium voltage circuit? or does the grouniding conductor have to be a medium voltage insulated conductor itself?
