Medium voltage grounding
Mike01
MidWest
Medium voltage installations ungrounded why would you run a ground in the conduit (with circuit conductors) if you have a ground in the pour of the duct bank? Under a fault 1-line to ground it would establish this as a reference upon a second ground fault would the current divide itself between the two paths and create problems?
