Two related questions:
I am laying out an installation of 3-conductor, shielded, 5kv cables (2.15-inch O.D. over sheath), and need to size pull boxes. According to 314.71(A), for straight pulls, the min. length of a PB is 48 x the cable diameter. This makes the min. length 48 x 2.15 = 8.5 feet!! Am i doing something wrong here?
Also, I need to size a cable trench (below grade) for the same cables. Does 110.74 apply to the width of a cable trench? I am bringing the cables into the end of the trench and then out of the side. This would be an angled pull and 110.74 references back to 314.71(B). Using this makes the trench 2.15 x 36 = 6.5 feet wide. This is assuming 1 cable in the trench. This seems a little too wide considering the min. bending radius of the cable is less than 2 feet.
Any help is appreciated.
