For those with experience specifying cable fault indicators, if you have medium voltage feeder cables that originate on a substation switchgear feeder breaker and span multiple manholes to finally terminate on a unit substation switch in a building, do fault indicators installed in the manholes provide any benefits? Keep in mind that the cable is un-spliced between the substation switchgear breaker and unit substation switch. Manholes are used to facilitate the pulling of the cable only.
