Cooper Dog
New member
I am working on a project where existing motors are being retrofitted to new medium voltage VFD's (older VFD's are being replaced). The motors are 27 years old, 4000V, 2000hp, wound rotors, stators are not inverter duty rated. The motors will be converted such that they will become like squirrel cage induction motors, hence the new configuration will be that the stators will now be connected directly to the new VFD's where as before the wound rotors where driven by the old VFD's (slip power recovery type). Owner does NOT want to replace or rewind the existing motors and feels that they are in good condition to be operated with newer technology VFD's. This poses a challenging design since these motors are part of a critical process.
I have been dealing with various MV VFD manufactures and of course everyone one of them has their own version of what type of output filter to use to protect the older motors. One manufacture is adament about using sinewave filters which is the ultimate protection for the motors and provides a nearly perfect output sinewave, however, they are expensive ($43K) and are apparently intended for long cable lengths (greater than 1000FT). Most other manufactures recommend dv/dt filters ($13k) which are used to lower the fast rise time of the PWM waveform.
Can anyone tell me if they have dealt with a similar project such as mine and what their solution was for dealing with older medium voltage motors with new medium voltage variable frequency drives?
Regarding output fitlers, I am "on the fence" regarding which output filter to specify so any opinions and real life stories would be much appreciated!
Many Thanks
Many Thanks
