sselman
- Houston, Texas
I am generally low power intrinsic safety focused and am not confident in applying NEC to motors.
We currently have a system for Class 1 Div. 1 hazardous area applications. The unit has Qty. 2 - 1/2HP Class 1 Div. 1 approved single phase motors, continuous duty automatically starting. They are NOT marked thermally protected.
Each motor has a thermal switch mounted internally to the winding to be used in conjunction with a motor controller or contractor control circuit.
UL508 HP rated solid state motor controllers are used to control each motor.
Can I wire the motors thermal switch in series with the 24VDC control circuit on the motor controller input and satisfy 430.32 (B) (2)?
